Buying Advice Tachometer got TO 35 gas engine
   / Tachometer got TO 35 gas engine #1
tmar04
YM 276
My TO 35 came without a tachometer. Can someone point me in right direction to locate one that will work electrically. My generator has been replaced with one wire alternator.
   / Tachometer got TO 35 gas engine #2
Try Yesterday's Tractors, There is a lot more info on the Ferguson TO Series there.
Since it's a gas tractor, you might consider just getting a regular electronic tach. It hard to find one with 0-3000 rpm scale on it however. Most are 8000 rpm and up. I used done one when I had my TO-30. look at the actron web site or just google "tachometers".
   / Tachometer got TO 35 gas engine #3
My 1955 TO-35 has the original " tractor-o- meter" ( or some name close to that) in the dash, but it doesn't function since the generator has been replaced by an alternator. I bought a small digital readout tachometer for under $30 that I attached to the dash . I use the same type tach on my riding mower, and it also shows engine hours. ( Tiny Tach is one name brand , but there are similar less expensive versions , on , for instance, Amazon.com) . ) If, however, your dash has an empty hole where the original tractor-o-meter was, the VDO 333-199 mentioned in the above post by K7LM would be a nice choice. There is also an alternator available ( last seen on eBay) that has a mechanical drive at the rear so that an original type cable operated tractor-o-meter can be used. That's getting a bit expensive, however. Or, you can buy a reproduction tractor-o-meter to put into the dash to look nice, but use the small digital tach for the actual rpm reading.
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
Adams 16T Tender Body (A55302)
Adams 16T Tender...
EZGO (A50324)
EZGO (A50324)
New/Unused CFG Industrial YSRT14 Min Skid Steer (A54865)
New/Unused CFG...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2018 Chevrolet Malibu Sedan (A55758)
2018 Chevrolet...
