Mowing TC 29 PTO WILL NOT STAY ENGAGED
   / TC 29 PTO WILL NOT STAY ENGAGED #1
JOEY29842
NH TC29
I have a TC 29 tractor with a Hydrostat transmission and have been using it quite a bit over the last week bush hoging. When I first started, The Rear PTO would occasionly jump out when bogged down but over the course of the last few days it has got a lot worse to the point that once i engage it, I have to hold it in position with my hand The handle actually pops out of position when i accelerate the engine now. Does anyone know what is happening and what i need to do to fix this. I'm certain I can fix anything that it may be, I just wanted to know if anyone knew what the problem before i started to dig. Thanks...Joey
   / TC 29 PTO WILL NOT STAY ENGAGED #2
I'm experiencing similar PTO problems with my 33D while using my rototiller. Did you attempt any linkage adjustments to solve the problem ?? Or did it turn out to be an internal problem ??
   / TC 29 PTO WILL NOT STAY ENGAGED #3
Did you ever find a solution to your problem? Having the same issue
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
Takeuchi TL140 (A47384)
Takeuchi TL140...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
2018 JOHN DEERE 310SL HL BACKHOE (A51242)
2018 JOHN DEERE...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
