TC18 Hydraulic High Pressure Retun Tube
   / TC18 Hydraulic High Pressure Retun Tube #1
Luremaker
Veteran Member
Ontario
Kubota L3130HST & NH TC18
I have to replace the Hydraulic High Pressure Return Tube on my TC18. It caught on something while I was mowing which pulled it down enough to have the steering rod bend it enough to kink the pipe causing a fluid leek. The pipe I have to replace is #4 in the drawing. The previous owner of this tractor tied into this line to supply a valve to run a cylinder on the front mount snow blower. It looks like quite a job to replace the tube so I was thinking of simply running a new rubber hydraulic hose from the valve through my cab and under the seat as a short term solution. In the fall I'd have the time to replace the metal tube. What do your guys think?
2nd Picture shows the kinked hose.
3rd Picture shows the line coming from the valve to the tube.
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
2019 JOHN DEERE 8295R LOT IDENTIFIER 185 (A53084)
2019 JOHN DEERE...
CFG Industrial SAII100 (A50123)
CFG Industrial...
