Oil & Fuel TC18 Starting
   / TC18 Starting #1
BuzzyG
Bronze Member
I need some help starting my 2003 TC18. I am just getting used to the machine, and I now know that I can't trust the fuel gauge. With the gauge on half-full, I let it run out of diesel. I filled it up - , and I can't get it started now.
Is it a hard one to get primed so that it gets fuel to the injector pump, or is it more likely that I have a fuel filter problem?
Thanks!!
   / TC18 Starting
I took off the fuel filter bowl, and I get no fuel at all to that point - no matter what the position of the valve.
I forced air into the full tank from the bottom end. I get bubbles in the tank - still nothing out the bottom end. Now that is a puzzle. I think there must be a kink that I can force air through, but the gravity feed of the fuel is not strong enough to get past the kink. Does that sound logical?
When I have more light tomorrow, I will take the cowling off of the tank and see what is happening between the tank and the bowl.
   / TC18 Starting #3
I have a TC18 and the fuel should flow fast enough to fill up the sediment bowl in a couple of seconds if the attach ring is left loose enough to let the air out as the fuel enters. Once you get that fixed, you will need to bleed the system. There is a bleed screw that you loosen up and fuel/air will start to bubble out of. I don't have the time this morning, but later on can send a copy of the pages from the service manual that show how to do this.
Guy.
   / TC18 Starting #4
I have attached a scan of the pages from the owners manual that explain the bleed procedure for the TC18.
Guy.
  • TC18_Bleed_Proc.PDF
2007 CAT 904B (A47384)
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
2012 Chevrolet Equinox LT SUV (A50324)
2012 Chevrolet...
