TC29 steering issue
   / TC29 steering issue #1
RoyK
Bronze Member
North Central PA
NH TC29D
I had to remove the power steering pipe from the pump to the steering wheel to have it reflanged. No problem. I topped off my power steering fluid and the steering words but is sloppy and can be difficult to turn. It's usable, but annoying and hard to maintain a straight line or a smooth turn when mowing. I figured I have air in the system and it'll work it's way out on it's own. Well, it's been weeks now and I still have the problem. Is there some process to bleed the lines?
   / TC29 steering issue #2
Try turning the wheels back and forth, lock to lock, a few times. Then give it a rest and do it again. Best might even be to jack up the front so the bubbles are compressed less while turning.
   / TC29 steering issue #3
and keep topping the ps resv off, if it has it's own resv.
soundguy
Thanks guys. I jacked it up and did as you said. Much better! Not perfect, but much better!
   / TC29 steering issue #5
post back if it does not get progressively better.. or gets worse.
also keep the oil topped off and watch it for the next few uses.. make sure there are not other issues at work.
soundguy
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
John Deere Lift Arms (A50121)
John Deere Lift...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
EZ-GO Freedom RXV Electric Golf Cart (A50121)
EZ-GO Freedom RXV...
