Tires TC33d rear tire position
   / TC33d rear tire position #1
popeye doyle
1999 New Holland TC33D
I have a TC33D with the R-4 tires. They currently are mounted in the wide position. Owners manual says they should not be swapped to the narrow position. The reason I would like to swap them is I have a 60" 914A mower deck and the rear tire widths is 62".
It looks like there is plenty of clerance if I did switch them but was wondering why the manual says not to switch them.
   / TC33d rear tire position #2
I just joined and remembered your inquiry. I have a TC33D with the R4s mounted narrow. The only issue I have noticed is the 3 pt. arms, if not secured, can rub on the tires. There may also be a clearance problem when mounting larger implements (cat I/II) to the 3 pt. requiring some jockying. I prefer the narrow setting for mowing and a 5' snow blower. good luck!
Thanks for the info. I do not use the 3 pt so that will not be an issue. I will make sure the arms not in the way of the tire. Only need to turn around the left tire as the mower deck is narrower than the tires.
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
