TC35DA glow plug timer
   / TC35DA glow plug timer #1
rsliker
Edinboro, PA
New Holland TC35DA
I have a TC35DA and hve determined that the glow plug timer is faulty. My research found testing info that the timer can be temporarily and quickly bypassed with the harness connector removed by jumping the brown to the black wire in the harness with the ignition switch on. Bypassing too long can burn up the glow plugs but I confirmed this to be a good system check. My question involves trying a Kubota part to replace this pricey timer. Prices on NGK timer S81NF are between $71 and $89. E bay parts search has a kubota NGK S81NL 12 volt timer for about $12! Tempted to try it as it has the same case and pin configuration. Has anyone else tried this? Could someone let me know how long their glow plugs stay lit with timer S81NF? (current New Holland Part #SBA385870301) Thanks, Randy
   / TC35DA glow plug timer #2
Lots of guys have run that and with really good luck. Give it a whirl!!
2018 KENWORTH T370 REAR LOAD GARBAGE TRUCK (A52576)
2018 KENWORTH T370...
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
2025 New/Unused Wolverine Ripper (A51573)
2025 New/Unused...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
