TC40 Weight
   / TC40 Weight #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
About how much does a TC40 MFD with a loader and a clamshell bucket weight?
   / TC40 Weight #2
For round numbers, figure 3,500 lb for the tractor and 1,250 for the loader. If you add a 3PH implement like a boxblade, you'll be over 5,000 lb. If your tires are loaded, add another 800 to 1000 lb depending on what is in the tires.
BTW: If you are looking at trailers, a utility trailer with two 3500 lb axles is not sufficient. By the time you add the tractor/loader and the weight of the trailer, you'll be right at the limit. If you add anything else, you'll be overloaded.
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
12.7 LITER DETROIT GENERATOR SKID (A50854)
12.7 LITER DETROIT...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
