TC45D Hi/Low range loss
   / TC45D Hi/Low range loss #1
BreezyRidgeTim
New Holland TC45D
While mowing tractor switched to low range. Lost lights on Hi/Low range switch on console, cruise light switch will activate when depressed, will not stay on when released. Hi/Low selector on joy stick also fails to operate. Ideas?
   / TC45D Hi/Low range loss #2
Tim, since you lost both the cruise and Rabbit/Turtle functions, I think you should check fuse #5. Take out the two Phillips-head screws on your instrument panel and carefully lift it out of the dash. On the left below the panel is your fuse block. It'll be covered with dust probably. Count from the left and pull the 5th fuse. If you fuse continues to blow, you may have a problem with your cruise control magnet being shorted or some other wire shorted. The cruise magnets have some history of failing. Most times they open rather than short out, but you just never know.
If you had just lost the Rabbit/Turtle function, I'd tell you to look for a loose wire going to the hi/low solenoid under the LEFT-side operator's platform, but both speed shift and cruise points to the fuse as the problem.
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
2014 KENWORTH T800 MIXER TRUCK (A50854)
2014 KENWORTH T800...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
