TC45D transmission issues
   / TC45D transmission issues #1
NM tractor
New Halland TC45D
Tractor has a hydrostatic transmission, it is stuck in reverse. The pedal for reverse will not move and the forward pedal will go the the floor without any resistance.
The PTO and 3ph work fine. When I start the Tractor a put it in high or low range it starts going in reverse, the only way to stop then is to turn off the key, I can't pull it out of range.
   / TC45D transmission issues #2
That kind of looks like a linkage came loose, probable related to the forward pedal, and jammed the reverse pedal down. Either that or a stick is jammed there somehow.
Have crawled underneath and check for any obvious broken or loose parts?
Got it in the barn this morning, don't see anything broken but haven't pulled anything apart yet. Cleaned the pump filter and changed the larger hydrologic filter. Did notice that the fluid was not clear, a bit milky.
2017 Ford Expedition SUV (A50324)
2017 Ford...
RoGator RG1100C (A52748)
RoGator RG1100C...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2016 Dodge Charger SRT Hellcat Sedan (A50324)
2016 Dodge Charger...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
