TC55DA rear lift lever
   / TC55DA rear lift lever #1
Twistedgrip
New Holland TC55DA EHSS
I have a TC55DA EHSS. The hand lever for the rear lift broke at the shaft arm. There was enough of the arm remaining that we contemplated a weld repair. While contemplating we attempted to rotate the shaft in the up direction to see if we could actually perform the task but the shaft WILL NOT rotate. Has anyone else had this problem? Is it possible for something internal to get out of position if the shaft rotated too far in the down direction? This should be a simple repair but it’s turning into a difficult one. All comments welcome
I pulled the hydraulic speed control valve assembly so I could see inside and found one of the little “fingers” out of position. Pushed the plunger back so it could fall into its proper spot and now it works as it should. I did weld it back together and saved some $$
   / TC55DA rear lift lever #3
Thanks for letting us know!!
2018 JOHN DEERE 317G SKID STEER (A51246)
2018 JOHN DEERE...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
CASE IH 2555 4R COTTON PICKER (A51247)
CASE IH 2555 4R...
2024 JOHN DEERE 461R LOT IDENTIFIER 166 (A53084)
2024 JOHN DEERE...
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
