TD95D Low fluid levels-low factory fill?
   / TD95D Low fluid levels-low factory fill? #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
I have a TD95D with 100 hrs on it that a purchased used with 93 hrs on it. I've been going over it because the PO did not do the 50 hrs maintenance on it. I checked the fluid levels in trans-hydraulic compartment and the final drives over the past few days and found that they were never opened(painted bolts all brand new looking and on really tight). I added 2 gallons to the trans=hydraulic compartment and a quart to each final drive section. I checked the FWD and the plug had obviously been removed at least once before brecause the paint was chipped on the plug head. I added maybe a half pint. There is no sign of leakage anywhere.
Is it common for these reserviors to come from the factory with less then the specified oil quantity in them?
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
