Terramite hydraulic problem
   / Terramite hydraulic problem #1
scrout
British Leyland 154
My 1998 Terramite T6 seems to have a hydraulic problem, maybe more than one. After lifting a heavy log on the FEL I tried to turn and heard the reliefs (or at least some weird noises) Now my hydraulic steering turns right, but not left.
The Terramite runs a dual pumps that drive forward and reverse. Prior to this event it would go forward and then hit a kinda second gear automatically, now it just stays in the "low" speed. They seem to make more noise now too.
What i am wondering is if I have a seal blown in the steering ram, which seems to work a little better while I am moving forward, and this is limiting the pressure available for the forward drive? Or maybe it is the steering valve?
Or the two are complete unrelated which would suck.
Appreciate any help here, thanks.
   / Terramite hydraulic problem #2
I can't be much of a help-I am not familiar with that machine or it's hydraulic system at all...
I can only offer the basic advice:
Fluid clean, clear and not milky or foamy looking?
Fluid at the proper level?
Filter replaced?
   / Terramite hydraulic problem #3
Hopefully you have figured it out by now... but just in case, I had similar issues with my T5C. I finally tracked it down to the fluid level. (Well, actually it was the first thing I checked and corrected, the problem went away after that.)
2022 Case IH Steiger 470HD AFS Connect Quadtrac 4WD Tractor, (A50657)
2022 Case IH...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2013 Jeep Grand Cherokee SUV (A48082)
2013 Jeep Grand...
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
