Terramite T6/T9 replacement radiator
   / Terramite T6/T9 replacement radiator #1
djag12
Mountain Top
Terramite T6
Hi All. I have a T6 with a Perkins diesel. I need a new radiator. I have called Terramite and was told to contact engine manufacturer. Contacted a dealer for Perkins parts and was told $2600 plus shipping from the UK and It's on backorder for 180 days. Has anyone used a replacement if so what brand and model. Thanks for any help.
   / Terramite T6/T9 replacement radiator #2
i'm not sure if you want a direct bolt in or not, if so then I have no advice. If not then you could easily custom install an aftermarket radiator. Just make sure it's rated for your engine and make it happen.
   / Terramite T6/T9 replacement radiator #3
Go to the auto parts store and get a radiator with the same or similar dimensions that has the inlet and outlet placed the same as yours. I would think you should find something in the $150.00-$200.00 range. You may have to a little modification( plugging tranny coolent lines and maybe a different mount) but that is better than spending $2600 plus.
   / Terramite T6/T9 replacement radiator #4
A little late replying to this. You don't say why you think you need a new radiator. If there is anything left of the old radiator, your first stop should be a shop that specializes in radiator repair. I had a Kubota B7100 radiator that had a damaged core and was leaking like a sieve. Took the radiator to a local shop and they re-cored it, cleaned it out, re-brazed the joints, painted it, and had it back to me in three days. Looks and works like new and saved me mucho bucks. I would try that before looking for a replacement.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
RoGator 844 sprayer (A50490)
RoGator 844...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
