Backhoe Terramite TC5 hydraulic oil
   / Terramite TC5 hydraulic oil #1
brockwellauto
Terramite T5C
I just bought a 2004 terramite tc5. It is whining when I drive foward or backwards. I checked the hydraulic fluid and it is not even reading on the dipstic. I have called around and no one has even heard of the fluid that the manual says to put in it. It calls for API SFCD 15W-40. Some people have told me that sounds like motor oil and tractor suply told me to use universal hydro oil. PLEASE HELP.
   / Terramite TC5 hydraulic oil #2
It is motor oil , 15w-40 with an api service factor of at least "cd" which is no problem because thats an old rating , all the oil on the shelf today should be at least "CG". Terremite specifically advises against using hydraulic oil. Some hydrostats do whine a bit even when the oil is ok , so you're not alarmed. Doesn't mean the hydro is bad or failing.
Rather than topping it up this may be a good time to just drain it and change the filter, fresh start is good for piece of mind.
Ray
   / Terramite TC5 hydraulic oil #3
Just a heads up.
First off I don't know anything about your tractor but I have a 1990 vintage dozer that calls for "CD" motor oil in the transmissiom. I CANNOT use the newer "C" series oils. The oils later than "CD" and especially the currant ones like "CG" oils have addatives that make them to slippery for the operation of wet clutches and brakes. (The price you pay for progress). Also, you probably need a non-detergent oil to reduce foaming. Non-detergent multi viscosity is hard to find.
I would do some research and not jump on motor oil unless you are sure.
Probably a multiviscosity hydraulic tractor fluid that meets Cat spec TO-4 or TO-2 is what you will end up with if you have wet brakes and clutches.
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
