TG 1860 overheating
   / TG 1860 overheating #1
Rickyj66
Hi all,
I have a TG1860 that overheats often. For this size tractor the workload is quite light, no heavy bush just lawn. I took the thermostat out and I used a radiator flush but it will still overheat after 45 minutes of mowing. Any suggestions
Rick
   / TG 1860 overheating #2
Hose the radiator a few times from both sides. Start actoss the top and work down, then blow it from both sides with copressed air and repeat until the water runs totally clean all over. The start it and run until the radiator is fully dry (do this stationary). Tg's dont run hot normally. Put a tgermostat back in it too. The bypass hoses isnt blocked when there isnt a thermo so you loose coolant flow.
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
