TG1860G Kubota Lawn Tractor
   / TG1860G Kubota Lawn Tractor #1
Jesse11
Bronze Member
The power steering would turn all the way left when starting the engine. I unplugged the wire at the top of the steering box just under the dash, it goes to a square sensor maybe , on the steering unit then plugged it back up. Now no power steering at all. Could that sensor? be bad? Anyone had this problem with this model? Thanks for any ideas,Jessy
   / TG1860G Kubota Lawn Tractor #2
the PS on my TG1860G has come and gone several times since I bought it new in 1998. On one occasion after I replaced the battery, the steering would pull to the left as soon as I started the engine.
The Workshop Service Manual has a procedure on page 5-S20 that remedied the issue for me.
I'll paraphrase it for you...
-jack up the front axle & support it in 2 places such that the front axle can't wobble up or down.
-turn the steering wheel left, then right, then stop at centre (straight ahead).
-find the service connector at the bottom right side of battery looking from front of tractor, at top of electronics module (a square connector with a loop back wire)
-turn ignition key on, do not start.
-unplug the service connector loopback.
-turn off the ignition key.
-re-connect the service connector loopback.
-lower front wheels to the ground, start engine and check for proper PS operation.
hope this works for you.
Pete
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A49461)
2005 Ford F650 SVI...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2007 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2007 STERLING...
