Thank you all from Gramps
   / Thank you all from Gramps #1
Gramps in NM
Bronze Member
Mimbres NM USA
Ford 8n, 2005 Taskmaster (Dongfeng)
I know I have another thread going and need all the help I can get but I just wanted to pass on this word. THANKS ALL. In trying to learn as much as I can and going thru my machine as I do yesterday I checked the injector pump for oil as has been recomended. Well, it did not seem to have any oil, found the drain plug and pulled it and got about 1- 2 oz. out . It is now full of 30wt, so a BIG thanks to all who have responded to my posts.
   / Thank you all from Gramps #2
Glad you are learning and we could help. I know twice as much about my machine after finding this site also.
Chris
   / Thank you all from Gramps #3
Hi Gramps,
I'm glad you are learning...same as me, also a Gramp. You wrote the pump was "full". There is a drain and a filler but also a level screw on the side.
I remove the drain and the fill and the other "level screw". Then I fill it until the level screw stops dripping. After a while it finally stops dripping and I close it up. You can fine online this level screw.
Good luck!
   / Thank you all from Gramps #4
Hi Gramps,
I remove the drain and the fill and the other "level screw". Then I fill it until the level screw stops dripping. After a while it finally stops dripping and I close it up. You can find online this level screw.
Good luck!
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
HOME MADE SMOKER / FRYER TRAILER (A52472)
HOME MADE SMOKER /...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
