The best way to fix this (censored) slow leak
   / The best way to fix this (censored) slow leak #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
My JD has original front tires, turf tread on a 14 inch rim...and although the tread is fine on both, one of them has a slow leak in the tread right inside the outer tread edge...the tire has not been punctured but is leaking because of a thin spot in the carcass, I have put two plugs in the area but it still leaks about 1 -2 psi per hour. I have never used any type of tire sealant but am considering using it to stop the leak rather than take it to a shop for dismounting and a patch on the inside. The label on Slime brand sealant says the sealant remains liquid and I would try using it, but what if it doesn't stop the leak, would the stuff cause any complications? Thanks for any input and advice.
   / The best way to fix this (censored) slow leak #2
The slime is supposed to be changed after a year, I think it says on the label. It can also lead to corrosion of the rims.
There is aan aircraft product, that doesn't have the water component, so should not lead to corrosion.
You can get more information at Home
I just put retread aircraft tires on the front of my JD 1050. With 26 plies on these babies, I should be laughing at the mesquite thorns now! :)
   / The best way to fix this (censored) slow leak #4
I agree, put a tube in it. If it is leaking through the sidewall, it will just start somewhere else, if you fix this one. I never found the tire sealer goop to work well on a slow moving vehicle. By the way, if both front tires are the same age, put a tube in the other one, too.
   / The best way to fix this (censored) slow leak #6
I had a tube put in one of mine last summer. It didn't last a day, before leaking again. While I am not opposed to tubes in some instances, with the use my rig gets, they are not worth the money spent on them.
Put a tube in it.
I appreciate the advice about using a tube but I mentioned in the original post that I don't want to go thru the headache of dismounting the tire or having a shop do it. There are a huge number of things around my property that will puncture tires and tubes, thorn bushes, old nails long since buried, etc. Both front tires have been plugged at least half a dozen times each and to add a tube to either would just create a lot more work the next time I get a puncture. What I want is a GOOD quality tire sealant that will last and not cause any corrosion.
   / The best way to fix this (censored) slow leak #8
Can't help on any particular sealant to use, but I have been astounded on the abuse that a foam filled tire can take. I have seen tires where the lugs have been ripped clean off and the operator continues on full guns.
If you have lots of tread left, you might consider.
I think that when I replace my tractors tires; I am very tempted to go down that road.
Just some food for thought.
   / The best way to fix this (censored) slow leak #9
I have had real good luck with linseed oil. It can be found in hardware stores, in metal containers. Take the air out of the tire, pour in the linseed oil, shake it well, then air it up.
Wolverine Quick Attach Stump Grinder (A50515)
Wolverine Quick...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
20305 (A51694)
20305 (A51694)
2008 Volkswagon Touareg (A50515)
2008 Volkswagon...
Year: 2018 Make: Infiniti Model: QX60 Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2018 Make...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
