The little Subaru gives up the ghost
   / The little Subaru gives up the ghost #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Was running my tractor a bit yesterday and it wasn't acting right, even though then engine wasn't hot yet (i.e., not the infamous vapor lock issue). I only used it for about 15 minutes. I went to crank it today and the engine wouldn't turn over at first. It finally turned over and started but ran very rough. I backed out of the garage and the engine quit. When it started this time, there was a lot of smoke. Never a good sign. The smoke smelled like burnt motor oil. I cranked it again with similar results.
I got off and opened the hood and could see oil at the bottom of the tub. Maybe it Hydro-locked and I blew a seal when I first tried to crank it. It's not like these Subaru carburetors have been known to leak. ;).
So, now it sits in my driveway. I looked up the towing instructions and couldn't figure them out. On the one hand, it talks about opening a bypass valve. But then it talks about connecting a bypass hose. There's no fitting on one of the indicated connection locations. So, I guess I'll be calling Terry in the morning.
   / The little Subaru gives up the ghost #2
Bummer.... on the 425 I thought there was just a bypass valve and no hose required for slow towing.
Polaris Side by Side (A50324)
Polaris Side by...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
