MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,022
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Well, its just a fuel issue, but it feels that way! :laughing:
Two weeks ago I was brush hogging at our tree farm and it started sputtering and not running right. I managed to work the choke and throttle to limp it back to the trailer just in time before it died. Got it home and started poking around. I found that if I choke it a tad more than 1/2 choke, it runs fine. So, that means too lean, not enough fuel.
- I made sure the fuel line is clear all the way to the fuel pump.
- Changed the fuel filter that was in that section of line.
- Made sure fuel is coming out of the fuel pump to the carb.
- Repair manual suggests the low idle screw adjustment.... guess what? Where the low idle screw is supposed to be, there's just a plug.
Anyone know if that plug comes out? Or is it a factory sealed non-adjustable deal?
I think I'm going to replace the fuel pump for starters. Even though fuel is passing through the pump, I wonder if its supposed to supply more than it is? I bypassed the fuel pump and ran the fuel line from tank, through shutoff valve, through filter to carb directly. I filled the tank enough so the fuel level is about 8" higher than the top of the carb. It still runs at 1/2 choke in this condition.
Today, while mowing the lawn, I noticed when I backed up and stopped abruptly, the engine sputters, so I'm wondering if there's a problem with the float/needle. The fuel level was down to about only 2" above the carb at that point. So, again, I'm wondering float/needle or lack of fuel pump?
Inspecting the float/needle is free, so I guess I'll do that first, then replace the fuel pump. If that doesn't resolve it, I'll look for a carb rebuild kit, or a whole new carb.
Any thoughts? Thanks!
