Thinking of buying Land Pride RCF2760
   / Thinking of buying Land Pride RCF2760 #1
330T
Melbourne Ky
Kubota L3800
Going to spin it with a Kubota L3800. I've recently cleared several acres of HoneySuckle with a Bobcat Forestry so i'm left with "chips" and some grasses and other stuff starting to spring up. Say it a total of 5 acres. I'd like something a bit tougher so i can run down other smaller brush, vine, and wild rose.
Am i going over kill? Should i do the RCF2060? Please comment
   / Thinking of buying Land Pride RCF2760 #2
I run an RCR2672 with my L5740HSTC, the RCR2760 at 1002 pounds and RCF2760 at 955 pounds are are within a few pounds of each other with the RCF2060 at 620 being significantly lighter.
As I don't own an L3800, I can only extrapolate from my experience and my inclination would be to go with the RCF2060 as I am concerned how much the 955 pounds is going to affect the fairly light 3800.
Your manual should give you an idea on recommended weights on your 3PH.
Again, I am just speculating and someone with real experience with the 3800 will maybe show up.
   / Thinking of buying Land Pride RCF2760 #3
I think the L3800 has a lift capacity of 1400 pounds 24 inches behind the arms. That is going to really test out your hitch with a mower that heavy. Like you I LOVE a stout mower, gives confidence and its fun but I've had a too heavy of mower on a tractor before and its pretty miserable to operate with it's weight back there wagging the tractor.
Does the 3800 have a aluminum rear axle on it? If it does I would go with the 2060 for sure. The 2060 will cut down any wild rose in Kentucky and any vine also. If you do decide to get the heavier mower you will for sure HAVE to have front weights or a loader on when your mowing,if you decide to use the top link and lift up the mower with the hitch. You could leave off the top link and use the mower in a "simi-mount" configuration where its always riding on the back wheel.
On those two mower I notice that the 2760 is listed at 955 pounds and the 2060 at 590 pounds. Thats a big differnce and the lighter one would be much more controllable on your tractor. Here is another benifit of the 2060, it has very high blade tip speed of 16,300 feet per minute. The heavier duty 2760 has a slower 12,380 feet per minute. The higher tip speed of the lighter mower should (in theory) give a nicer and cleaner cut if that is important to you.
With your tractor I would go with the lighter 2060 if it was me. I think you'll find it is a plenty tough little mower for what you want it to do and will leave a finer cut and be easier on you and your tractor's hitch. That said, if your going to mow with a loader on, if you have fluid in the tires, if your rear transaxle is cast iron,if you not concerned with a "lawnmower" quality of cut and your going to mow over some bigger saplings then the heavier 2760 is the mower for you.
   / Thinking of buying Land Pride RCF2760 #4
Going to spin it with a Kubota L3800. Should i do the RCF2060?
I pull an RCF2060 behind my Kubota L3560. They are a good match.
Plenty of PTO power to run the RCF2060. There have been times pushing through ten foot tall Jasmine that the tractor had hardly enough motive horsepower to push through the vegetation in HST/LOW but the RCF2060 has chopped happily away, in the rear. (I'm talking REALLY THICK Jasmine.)
I like being able to blow off all debris from the RCF2060 smooth, semi-sphere deck with a short blast of compressed air.
Well went to purchase the RCF2060 yesterday and the local Kubota dealer had a used RCR1860. A few dents and dings but nothing bad. They agreed to service the gear drive, and replace the cutting knives and sold it to me for $650. I couldn't pass that up when i was ready to drop $1600 on a new RCR2060.
So I added the LandPride pallet forks, and a carry all. Why you ask? I had the green light to spend $1600 so i figured why not. :mischievous:
   / Thinking of buying Land Pride RCF2760 #6
Good buy. Enjoy.
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2121 (A51244)
2121 (A51244)
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
