This valve instead of pilot valves on cylinders?
   / This valve instead of pilot valves on cylinders? #2
Don't you need a float spool for tilt part of TNT? I don't have TNT, but was just thinking on the order of stadard 3pt hitch float.
A comparison of check leak ratings might be in order also. 0.8L/min would roughly be 1/5thgal/min and if that much fluid loss would work, who knows? My loader load checks will hold a bucket of dirt up for days, but I don't know the specs to give you.
   / This valve instead of pilot valves on cylinders? #3
According to their schmetics, they have a double pilot check valve in there. What the manual doesn't give is the cracking pressure or the pilot ratio. These are important. The higher the cracking pressure the better, the CCM valves are 500 psi. FYI, thats the pressure applied to the dashed line (pilot control line) in the schmetic that goes into the check.
   / This valve instead of pilot valves on cylinders? #4
</font><font color="blue" class="small">( My loader load checks will hold a bucket of dirt up for days, but I don't know the specs to give you. )</font>
That is not what a load check does. The load check has nothing to do with how well the valve will hold up a cylinder when the spool is in neutral. The pilot operated check valve does that. Load checks are standard on just about every manufacturer's spools.
The load check on a spool will prevent the fall of a cylinder as the spool is shifted. It also prevents the backflow of oil from the work port to the inlet. It is functional only when the spool is shifted. Operationally, when the spool is shifted, the pump must build up enough pressure on the work port caused by the weight of the load before the cylinder can move. Sort of like preventing jerky operation.
Several of the Prince manuals give explanations of load checks and disclaimers that they function only when the spool is shifted, not when in neutral.
Thanks Ref, good point. I'll call Eaton on Moday and see what they say. Like I said I ordered that other valve you suggested for Surplus Center and then I found this one. I guess if the specs work out, I'll just return the one to SC and get the pilot one locally. Joe
   / This valve instead of pilot valves on cylinders? #6
</font><font color="blue" class="small">( Don't you need a float spool for tilt part of TNT? I don't have TNT, but was just thinking on the order of stadard 3pt hitch float.
)</font>
No..... Not changing the 3pt at all, it will still float like always. You are only replacing a vertical metal bracket with a hyd cylinder. This cylinder does not need to float - the metal bracket never did.
--->Paul
   / This valve instead of pilot valves on cylinders? #7
Mega_Me,
I think that valve will not require you to have check valves on the cylnders as TNT does, since they are built in.
I recently read a thread sarted by Henro and he ended using that kind valve and has worked out real good for him. But he makes an interesting point...
Using that valve, if a hydraulic line between the valve and cylinder were to blow, the cylinder would lose lose pressure and leak down. If this happened with the check valves mounted on the cylinder, it would not lose pressure. One other slight minute consideration (may amount to didly squat) is any bulging of the hydrauic hoses would also affect the rigidity of the cylinder.
   / This valve instead of pilot valves on cylinders? #8
</font><font color="blue" class="small">( standard on just about every manufacturer's spools.
)</font>
I had to get back to states and look at my repair manual and be sure before spouting off. These checks are at work port's passages. It says verbatim that the 5/8 check balls contain the oil in cylinders until spool is actuated. There are also valves called control check, that might be related to what you speak of. Possibly this is a different check valve arrangement as it's OEM industrial, not aftermarket. There are other features I'm not sure are common, such as cushion valves and anticavitation valves.
All in all, it''s an interesting fact you've brought up and something to consider before I would replace this loader valve with the 3 spool I've been contemplating. As always you're a great asset to the forum.
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
2015 Kubota KX91-3S2 Mini Excavator (A52377)
2015 Kubota...
Mongo Mover Aluminum Hand Truck (A52377)
Mongo Mover...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
2016 Ford Explorer...
