Loader Thought I would share - Loader/O-Ring Issue and Hydraulic Leak
   / Thought I would share - Loader/O-Ring Issue and Hydraulic Leak #1
OLV1071571
Bronze Member
Central Arkansas
Kioti RX7320P
So I was out working the loader last weekend and started to notice the bucket slowly dumping on its own. So I curled it back up and it started to fall again. Knowing I probably had a hydraulic leak somewhere I quickly brought it under my shop roof and shut it down. I took a look underneath and saw about a half a quart of hydraulic oil dripping from the hose quick connect and who knows how much I lost prior to then on the way back. I did the usual trouble shooting to see why it wasn't making a strong seal and finally determined it was the O-ring inside the female end of the quick connect. There were small pieces of hard rubber that were floating in the opening and the o-ring was starting to fall apart. (Note that there was a lot of tension and downward pressure on the hose as it came from the factory. My fault for not really catching that I guess).
Called up the dealer and they were super helpful and not only gave me a new o-ring but also 2 female quick connects just in case the entire connection had an issue. I have only had my tractor for just over 1 year now and have 140 hours on it. I always noticed hesitation when dumping the bucket and now I know why. So long story short, I replaced the o-ring and topped off fluid and we are back in business! Just hard to believe this was seemingly an issue from the beginning.
Thought I would share in case anyone else experiences the same.
   / Thought I would share - Loader/O-Ring Issue and Hydraulic Leak #2
Nice! Thx for sharing. I’ve heard several stories about the QDs creating issues.
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2010 Volkswagen Jetta Sedan (A48082)
2010 Volkswagen...
Bundle of 40 Gauge Pipe (A50860)
Bundle of 40 Gauge...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
1986 ASPT 30ft S/A Pole Trailer (A48081)
1986 ASPT 30ft S/A...
