Three point quick hitch weight distribution
   / Three point quick hitch weight distribution #1
prosparky
Niles, MI
2002 Simplicity Conquest
Hey guys-
I have a ballast box that I'm modifying to fit on a quick hitch. I need to properly locate the top pin mount before welding.Should the top link pin just rest in the quick hitch hook? I would reason that the top link is not meant to carry any weight since it only provides support in the horizontal plane on a three point without a quick hitch. Am I thinking correctly?
   / Three point quick hitch weight distribution #2
Yes, just set it using the center to center dimension of the QH (should be 18"). Note that if you have weight on the top hook, it will just transfer to lower pins, since the QH is rigid. However, I usually make implements with + margin on the dimension to keep the weight off the pin and make unhooking easier.
Thanks! I located it so it is a little loose on the top hook. I'm sure once I get the box filled with concrete, things will settle.
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
INGERSOLL RAND DD-16 SMOOTH DOUBLE DRUM ROLLER (A51242)
INGERSOLL RAND...
John Deere Bale Spear (A50515)
John Deere Bale...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
