throttle lever survey
   / throttle lever survey #1
magicheater
Veteran Member
central Wisconsin
Kubota B7800, B26 TLB
So on my L4350 pushing the throttle lever forward increases engine rpm's and on my B7800 pulling it back increases engine rpm's. When did they change that or is it a model difference? Personally I like the forward/go and back/stop
variation the best.
   / throttle lever survey #2
My theory is that Japanese swords cut on the pull stroke (backwards) so that's how their throttle works.
   / throttle lever survey #3
variation the best.
My 1980 B7100 was pull for more speed, push for less, my mid-90's B7100 was push for more speed, pull for less. My 2005 B7610, is pull for more speed, push for less (like the earlier B7100). My mid-90's G1800 is push for more speed pull for less, and is also on the left side, where the other three are on the right side.
The inconsistency is maddening. If cars where this inconsistent in the primary controls, we'd have a lot more accident (but officer, my OTHER car has the brake pedal on the right, and accelerator on the left....).
As a pilot, I prefer push for more power, as that is the way all airplanes are.
   / throttle lever survey #4
On ours the RPM's increase as you pull it toward you...kind of a pita if you knee is inclined to bump the lever...
...could knee bumping complaints be a reason? I dunno.
   / throttle lever survey #6
On my Kubotas, Fords and Massey Ferguson and one Case pull back and one Case forward and John Deere push forward...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
