Throttle tension adjustment?
   / Throttle tension adjustment? #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
On my new 4300, I've noticed that I move the throttle up to where I want it, let go, and it moves back down a bit to a slower position all by itself. It takes a lot of fiddling to get the RPMs to stay where I want them.
Opening the hood and pulling the side panel makes it obvious that, if there is an adjustment for this, it must be up under the instrument panel cowling somewhere? I don't have my tech manual yet for this machine, so I'm wondering if anyone can suggest the best way to get at the adjustment?
The Deere dealer said they had never had to adjust one before, and could only suggest pulling that cowling and looking around a bit.
Anyone been there, done that?
Thanks,
Bob
Bob Trevithick
   / Throttle tension adjustment? #2
Yes, been there done that. If you remove the 4 or so screws holding the instrument panel down and lift it up, you can barely get access (without major tearing apart) to a nylon inserted nut that clamps a friction plate against the throttle lever. If I remember correctly, you'll need two open end wrenches, one to grab the nut and the other to grab the head of the bolt. Kind of awkward getting in there without taking too much apart, but it can be done.
Tom
Thanks, Tom! I guess I will be tinkering tonight. Not that I mind tinkering, mind you... /w3tcompact/icons/smile.gif
Appreciate the reply!!
Bob Trevithick
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
FUEL TANK (A50854)
FUEL TANK (A50854)
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
