Throwing oil out the oil file tube
   / Throwing oil out the oil file tube #1
sthompson882
Jamestown, Mo
2400 Branson
My Montgomery Ward log splitter is throwing oil out the oil fill tube. What is the likely problem. It is a 10 1/2 ton Montgomery Ward, don't know the year it was made.
   / Throwing oil out the oil file tube #2
Over full.
Heated oil will expand.
Air saturated fluid.
   / Throwing oil out the oil file tube #3
JJ you make me laugh.
Air saturated fluid = check the suction line for leaks.
Tighten all the clamps or replace the hose if you have to.
   / Throwing oil out the oil file tube #4
Bad rings and blow-by. The combustion gasses bypass the piston rings and pressurize the crankcase on an old engine. That can blow the oil out of the dipstick or the breather. You can check the compression on the engine dry and wet to tell for sure.
   / Throwing oil out the oil file tube #5
Ok so now you have two different readers taking your original message two ways. You just need to clarify one thing. Is it the hydraulic oil reservoir or the engine that's throwing oil out the fill tube? I answered for the hydraulic reservoir and eddie48 answered for the engine. JJ mixed it up and answered for both.
   / Throwing oil out the oil file tube #6
Well,, this is the "hydraulic" forum, isn't it.
   / Throwing oil out the oil file tube #7
I was thinking hyd fluid.
My answer was for hyd fluid.
   / Throwing oil out the oil file tube #8
I'll add another, pump running backwards. Well you never know unless your are there.
   / Throwing oil out the oil file tube #9
Skyhook I answered out of today's topic's not out of a specific forum. I guess I could have looked closer and figured it out but I didn't. :)
   / Throwing oil out the oil file tube #10
Me, too. I saw Montgomery Ward and thought, "Old Engine". That's when my brain stopped.
2018 Dodge Grand Caravan SXT Van (A55758)
2018 Dodge Grand...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
1996 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
1996 POLAR TANK...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
CAT 416B (A47477)
CAT 416B (A47477)
