Apr 9, 2014 / throwout bearing direction #1 K kennyl123 Bronze Member Joined May 16, 2012 Messages 58 Location Pollock, LA Tractor Ford 2000 Hi folks, I removed my release bearing from hub on 1972 Ford 2000 and didn't notice which side of bearing was facing pressure plate. Please help
Apr 10, 2014 / throwout bearing direction #2 P puckgrinder85 Platinum Member Joined Oct 18, 2010 Messages 574 Location WI Tractor '13 Yanmar Lx4100 Do you have any pictures or diagrams to show what the bearing looks like? Usually the flat side faces the pressure plate. Are there any retainers holding it to it actuating arm or is it hydraulic?
Apr 10, 2014 / throwout bearing direction #3 LD1 Epic Contributor Joined Apr 30, 2008 Messages 22,539 Location Central Ohio Tractor Kubota MX5100 Yep, pictures are worth a thousand words. But most throw out bearings, there is only one way they "can" go that they will work right.
Apr 10, 2014 / throwout bearing direction Thread Starter #4 OP K kennyl123 Bronze Member Joined May 16, 2012 Messages 58 Location Pollock, LA Tractor Ford 2000 Thanks for the help
Apr 10, 2014 / throwout bearing direction #5 LD1 Epic Contributor Joined Apr 30, 2008 Messages 22,539 Location Central Ohio Tractor Kubota MX5100 No problem.:thumbsup:
