thwacking noise from deere 455 w/60 inch mower
   / thwacking noise from deere 455 w/60 inch mower #1
steve74
Carlisle, PA
Deere 345
So I got the lift issue sorted out adequately (I think) but shortly after I started mowing yesterday the mower started making a mild but persistent intermittent thwacking noise. It was audible, but dull and not not transmitted as a noticeable vibration, and seemed harmonic - it would do it for 10 or 15 seconds, then stop for a little, then come back. Initially I thought there was a helicopter passing by in the distance but when it persisted I killed the PTO and it stopped. It didn't seem to change or get worse, so I finished mowing. Definitely PTO related - doesn't do it just running around.
Checking later there was some play in the PTO shaft, but it didn't seem loose. I assume there has to be some play. The belt looks good, and none of the blades seem to wobble so I think the spindles are fine.
Anything else I should be checking or testing? Is this common?
Steve
   / thwacking noise from deere 455 w/60 inch mower #2
Is there enough grass build up under the deck so one of the blades could be hitting it? Possible belt is flopping slightly or idler bearing getting rough?
   / thwacking noise from deere 455 w/60 inch mower #3
Steve,
Did you check the belt all the way around? Could be a chunk missing from the inside of the belt.
Check your idler pulleys and the spring tension.
Also did you try changing the rpm? Did it make it go away or make it worse?
Richard
Thanks. The deck was clean, and I blew some dry grass out from the belt area but it wasn't particularly bad.
I checked the belt but didn't actually take it off. Could be a chunk missing that I couldn't see. And the idler bearing is a good thought - I suppose when I take the belt off would be a good time to check on that.
   / thwacking noise from deere 455 w/60 inch mower #5
Could be picked something up under the deck also. I will also add you could have a belt coming apart and you may not see that till it happens. Had that on deck two years ago. Really was glad when it fail for turned out replacement belt was quite.
   / thwacking noise from deere 455 w/60 inch mower #6
I'd guess you have a loose or bent piece of steel that is tack welded around the inside of the deck, just near the tips of the blades. That, or a bent blade or other lose part.
Flip the deck over and look for the shiny part. ;)
   / thwacking noise from deere 455 w/60 inch mower #7
Did you ever find the source of the noise?
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2019 Caterpillar DP35N Forklift (A51691)
2019 Caterpillar...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
