tile questions
   / tile questions #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi all I have done tile before, but its been a few years and products change.
We did a pretty big remodel, moved the kitchen to our large mudroom and the mud room to our small kitchen.
I am planning on doing a brick look tile herring bone pattern ceramic tile.
I have 2x10 joists on 16'' spacing with 3/4 ply on top.
The only issue here is it was nailed in not screwed.
So I will screw and glue (from the basement) before I put any tile down.
I ran the deflection calculator at J Bridge and came out fine for tile or natural stone.
I am still in the process of ripping off the 1/4'' luan that is nailed every 3'' that held parquet flooring used a tile shark that was a fun way to rip up that flooring.
Once that is done my plan is to use cement backer board. Is there one that is recommended over the other. I do not have the $$ to do ditra.
What about thinset. I am using an abbey brick product and cannot find any info on what they recommend other then 3/8 grout spacing.
Ill try to get a few pics when I can. thanks!!
Once that is done I plan on building a few shelves and a bench or two in there.
   / tile questions #2
Sounds like you are all prepared for the job. We put unglazed quarry tile in our kitchen. Went down great - then we got to the grout. Both the wife and I agreed that a dark grout would look nice against the brick red quarry tile. Bottom line - the dark grout stained the quarry tile and we spent a month and a half - washing, scrubbing, brushing, etc, etc. Finally got it to looking nice. The salesman told us when we went back to see him - - OH, you should have put a sealer on the unglazed quarry tile BEFORE you grouted it. Live and learn.
Have fun.......
   / tile questions #3
I recently did tile in one of my bathrooms. With the advice of the guy at HD, I used per mixed thinset. It was a bad decision. the premixed thinset didn't cure and the tiles came lose.
I had to remove all the tiles and start over. I mixed the thinset out of a bag and had no more issues with the tiles coming lose
   / tile questions #4
The regular 1/2" 'hardibacker' cement board would be fine as a substrate over the 3/4 ply. The plywood being nailed down shouldn't be any problem. Screw the hardibacker down. I had a 8x12 area of tile that was on only 1/4" hardibacker that was screwed down over nailed plywood. No cracks or problems for 15 years. When I pulled it all up, took almost a day and a half to get it all up...it didn't want to come up. Had to use an air chisel and even then, came up in small pieces.
   / tile questions #5
As kenmac said, DON'T use the premixed thin set. Get the 'polymer fortified' mix in a bag.
   / tile questions #6
I'm a big fan of James Hardie products. One of the reasons I like them is that they explain how to install their products in an easy to read format on their website.
I copy and pasted this from their page at https://www.jameshardie.com/d2w/installation/hardiebacker-us-en.pdf
Floor Installation
(Interior Application Only)
We recommend 1/4” HardieBacker®
board for floor applications, unless 1/2”
thickness is needed for transition.
1 | Ensure subfloor is structurally
sound
On existing structures:
• Ensure subfloor is not damaged.
Replace any loose, warped, uneven or
damaged sections of floor.
• Make certain subfloor is a clean and flat surface.
For all floors:
• Use minimum 5/8 exterior grade plywood or 23/32 OSB with Exposure 1
classification or better, complying with local building codes and ANSI A108.11.
• Joist spacing not to exceed 24” on center.
• The floor must be engineered not to exceed the L/360 deflection criteria (L/720 for
natural stone), including live and dead design loads, for the specific joist spacing used.
2 | Determine layout of HardieBacker® cement board
• Stagger all HardieBacker® cement board joints. Do not align with subfloor joints.
• Never allow all four corners of boards to meet at one point.
• We recommend an 1/8” gap
between board edges.
• Keep sheet edges 1/8” back from
walls and cabinet bases.
• Score and snap boards to required
sizes and make necessary cutouts.
3 | Attach HardieBacker cement board to subfloor
• Apply a supporting bed of mortar or modified thinset to subfloor using a 1/4”
square-notched trowel.
• Embed HardieBacker cement board firmly and evenly in the wet mortar.
• Use the fastener pattern as a guide. Fasten HardieBacker cement board with
specified nails or screws (as listed in “Materials Required”) every 8” over the entire
surface. Keep fasteners between 3/8" and 3/4" from board edges and 2" from
board corners.
• Set fastener heads flush with the surface without overdriving.
4 | Tape joints prior to tiling
• Prior to setting the tile, fill all joints with
the same mortar used to set the tiles.
• Embed 2” wide high-strength alkaliresistant
glass fiber tape in the mortar
and level.
   / tile questions
thank you!! I was thinking since I have the space between the floor and wall to use 1/2'' Cement board.
I will look at the polymer fortified. I would rather mix it myself.
I have tile and stone sealer from when I did a field-stone project. I will make sure I put that on the tiles to keep it from staining, (good call!!)
   / tile questions
Eddie thank you!! I appreciate it! One question....
When they say they recommend an 1/8' gap between board edges what does this mean. Is it sides and ends? I am assuming that its for expansion, then the tape would go over the joints to keep them "clean" to allow expansion.
Thanks I know you do a lot of tile work and I appreciate the help!
   / tile questions #9
As for thinset, Ardex is probably the best of the best right now. You'll have to go to a tile supply shop to get it. But for what you are doing, I'd use the Versa Bond thinset sold at Home Depot. Probably just the basic grey for around $15 a sack. Your tile should say on the box what size trowel to use. Just follow the instruction and keep your thinset wet. Do not put out too much thinset, or it will start to dry on you and you will end up with tiles that do not adhere, and make that hollow sound. I never put out more then two square feet at a time, and most of the time I'm making too many cuts to spread any at all, so I back butter each tile and install them that way.
Home Depot also sells PolyBlend grout, which is good stuff. Be sure to get the sanded and keep it wet too. For bigger grout joints, I like a stiffer float. Get sponges designed for grout, they make a difference!!! Just don't use too heavy of a hand with the sponge,that's what gives you your finished look. Push too hard and you take away too much grount.
Sealer is actually a catalyst that hardens your grout. They are all about the same, just don't expect any of them to stop any serious staining. If there is a chance of staining, go darker in grout color.
   / tile questions #10
That is to deal with the flex in your floor. Even if you do not feel it, there is always going to be some movement. That gap allows the floor to move just a bit, and not bind up the backer board. Floating floors do the same thing around the perimeter. If something moves, it needs space for that movement. So yes to sides and ends, and yes to keeping the joints clean.
If you cannot find the special fiberglass tape for your joints, look in the sheetrock area. They have it there in the stores I go to. It will have bigger gaps in it, and it's kind of a cream color.
2015 GMC Yukon XL SLT 4WD SUV (A50324)
2015 GMC Yukon XL...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
