Tiller Leaking On Top End?
   / Tiller Leaking On Top End? #1
Jackrabbit_Slim
B.C. Canada
B2710
Just got a Maschio W125 tiller. (Chain drive.) Noticed a bit of oil seep on the top end. This is coming from somehwhere around the area where the drive shaft goes through the side of the tiller to meet the top sprocket of the chain drive.
I'm thinking a bearing for the drive shaft is seated in the flange support that bolts onto the side of the tiller, and I suspect there should be a gasket between the flange and the side of the tiller.
Anybody know if there is an oil seal anywhere in this assembley, or am I getting worried over nothing?
Thanks,
Slim
   / Tiller Leaking On Top End? #2
Leaking from a breather isn't much to worry about.. leaking from a shaft is. Could mean any number of things.. like a bad bearing that has let a seal go .. or the breather cap is plugged, and oil is being forced out at a seal.. this is particularly bad as the seal may be forced out.. etc.
DO investigate it.. an exploded parts diagram will help.
Soundguy
   / Tiller Leaking On Top End? #3
how much oil are you talking about? is it possible that it was slightly overfilled? wipe it clean and chek the oil level.
2011 Chevrolet Traverse 1LT SUV (A50324)
2011 Chevrolet...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
1266 (A50490)
1266 (A50490)
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
