Tiller Tiller Questions
   / Tiller Questions #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I am planning on buying a tiller finally. I had to wait until the prices went up so that I could spend as much for as little as possible......
Anyway, with, say a 56" tiller, how long would it take to till 3 acres about 3-4" deep to get ready for planting bermuda? This is heavy clay not rocks. I read a review on here earlier about it taking 5 hours to till a 40 by 75 garden. According to my calculations it would take 712 hours to till 3 acres! If its that slow, maybe I should just use my disk again?
This is clay that came out of the digging of my pond almost 5 years ago. I have been planting cover crops on it, and it is somewhat improved, but still when I disk it, if conditions aren't perfect I end up with 1" - 2" clods even after several passes. I figured a tiller would chop it up finer.
   / Tiller Questions #2
" I read a review on here earlier about it taking 5 hours to till a 40 by 75 garden. According to my calculations it would take 712 hours to till 3 acres!"
Yeah, I know. I used to have a tractor like that. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Seriously, I tilled 2 1/2 acres of corn stalk ground in about three hours when we planted our fescue. This was done with a 48" tiller. /forums/images/graemlins/smirk.gif
   / Tiller Questions #4
I have an 84" on a 58hp / 50hp pto 4720
Kinda sandy soil,,,, some clay
I can do about 1 acre in less than an hour. (open area - not my garden )
My Garden area was Probably 100' x 100' last year....
Less than an hour also,,, it has a number of obstacles that slow me down some on that.
I would think a 54" + slightly smaller tractor would not be much more than twice the time...
I go full depth on the tiller which leaves over 6" of tilled soil over the hard pan..... at least in my type soil...
I tried the disc at the first of the year and really couldnt get the kind of penetration and type soil condition I desired....
If you deep broke / busted the soil first then maybe the disc after to smooth out somewhat and break up soil more would be appropriate.
I plan to use the tiller pretty much as it was so stinking expensive for a deere 84" tiller that I will have to use it a lot to seem worth having spent the bucks for it.....
I have lots of other work to use it on besides the garden though,,, so I am very pleased with it.
   / Tiller Questions #5
Mathematically, it would take 3.5 hours to till a 56in x 5.25 miles doing 1.5 mph.
(about the speed I till)
add switching directions and potty breaks and I would say about 9 beers.
12oz ers to be exact.
   / Tiller Questions
Based on these responses, it sounds like I might do the 3 acres in 4.5 to 6 hours. Quite a bit more time than it takes with the disk, but I just haven't got real good luck with the disk in this soil. In better soil on my property the disk does fine, but not this soil. If it takes 6 hours, thats probably worth it.
Thanks for the replies.
   / Tiller Questions #7
Hoye tractor is in Texas. If he is close, you might look at the Japanese tillers. They can till much faster if you have a multi speed PTO. A used Japanese tiller in good shape usually sells for about half what a new US tiller does. They don't really like hard pan but if it was busted up first they do a great job. They also have gage wheels and that makes holding a set depth pretty easy and adjustment is just the turn of a wheel.
   / Tiller Questions #8
Alan, why not disk first and then till. If the clay has been partly broken up by the disk the tilling will go faster.
MarkV
   / Tiller Questions #9
I think you'll find that you're able to go a little faster with the tiller if this is not virgin soil. Soil that has been turned a good bit in the past is usually not quite so difficult to till and you can keep the tractor speed up a little.
The real challenge is soil that has never been tilled/disked/etc and is very compacted.
I suspect you'll enjoy the seat time regardless. John
   / Tiller Questions #10
</font><font color="blue" class="small">( 5 hours to till a 40 by 75 garden )</font>
Now that would really be slow. /forums/images/graemlins/laugh.gif I just had a 40" tiller with a main garden plot of 83' x 103' and another plot of 83' x 15' and it never took an hour to do both of them.
2014 UTILITY DRY VAN TRAILER (A43005)
2014 UTILITY DRY...
2000 Gallon Nurse Tank on Semi Pup Trailer (A47369)
2000 Gallon Nurse...
Front Weights & Spacers for international 5088 (A47484)
Front Weights &...
2025 Wolverine TL-12-72W Hydraulic Rotary Tiller (A47484)
2025 Wolverine...
2016 John Deere HPX Gas Gator 4x4 Utility Cart (A44572)
2016 John Deere...
2019 Takeuchi TL8 Skid Steer (A47484)
2019 Takeuchi TL8...
