tiller size
/ tiller size #2
I have a 48" that I use on the back of my BX23...I don't use it all that much but it works very well.
Don
/ tiller size #3
Three sides to the issue: First, how heavy is it vs. size of your tractor; second, how much hp do you need to run the thing; third, how wide is the tire track vs. the tiller.
An L2500 weighs something like 2700lbs, so it should be able to handle a 5ft tiller with no problem, maybe even a 6ft, weightwise. But it only has 22.5 pto hp, which is a bit low for a 6ft. and you'd probably do better with a 5ft.
This also depends on what kind of soil you have... sandy soil needs less power than heavy, moist clay, for example.
Regarding tire width, you'll have to measure your L2500. Many tillers can be offset some left or right, so even if the tractor is wider than, say 60", you can still use a 5ft tiller by shifting it to one side and making overlapping passes.
/ tiller size
thanks guys------love the knowledge on here
/ tiller size #5
You don't have enough horsepower for a six foot tiller. Stick with a five footer or less.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2019 K&K Equipment Trailer, VIN # 1K9PE2026KA175452 (A65563)
2019 K&K Equipment...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
Hedge Posts (A65640)
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
