Time to build a new shop, need some input.
   / Time to build a new shop, need some input. #1
STx
Veteran Member
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I need to build a new shop for all my stuff at the new place. On the last place, I did a 40 x 50 x 16 (My shop build) because that's all the concrete I could afford. This time, I'm going bigger, something in the neighborhood of 5,000 sq/ft. My question though, is would you do a longer, thinner building like a 50 x 100 or would you prefer a 60 x 75 or 60 x 80? I'm leaning towards the 60 x 75 because I think the more square layout looks better. I'm also going to plan it with a mezzanine in one bay that I'll use for an office, bathroom and little bits storage, things like bolts, plumbing fittings, etc.
   / Time to build a new shop, need some input. #2
Not sure what all you plan on doing in it, but plan for things like heat, welder, an automotive lift, and move closer to me so I can come over and use the lift.
I learned a lot on the first build in regards to all of that which will be applied this time. It'll have it's own meter with 200A service, power won't be an issue. I'll be running conduit in the slab this time for electrical and water from one side to the other, I really wish I'd done that the first time. I did a 6" thick, 4000 PSI slab with #4 rebar on 12" last time, this one will be the same, you can't redo concrete. I used batt insulation on the first build, I'm going to bite the bullet and spend the money on spray foam this time so the building will be completely sealed. I had a rat problem in the first one because of the little holes, they did a lot of damage.
The only thing I'm really waffling on right now is the footprint.
   / Time to build a new shop, need some input. #4
It hard for me to compare, my shop is smaller and is 28 deep by 30 wide. Of course I wish it was bigger. The way I use mine, working on cars, trucks, my tractor etc much deeper than 30 to 40 feet woukd just be storage. I have a work bench in front of the bay I work on vehicles. The 28 depth is perfect for cars but to short by a couple of feet for my truck, which fits, just a little tight.
In my mind the 50x100 would be best but then it seems like you would need a bunch of overhead doors.
I tend to put stuff along the walls and use the middle area for working on stuff. Right now, I've got pallet racks on one end wall and storage shelves on the other. Then against one side wall is my metal rack and chop saw with the welding table just a few feet from the other side wall. There are 2 roll up doors directly across from each other on one end, that's where I pull vehicles/equipment in to work. Everything else happens in the middle of the shop. I've always used my shops like this, lots of open space for working on stuff in the middle and the walls are storage or dedicated workstations.
   / Time to build a new shop, need some input. #6
That is what I do also. Mine is 54'x75', I am glad I didn't go with my first plan of 40'x60'. A big wideopen center sure does come in handy. It is so nice to be able to drive the tractor in, turn around, change implements and drive out. If I ever get a chance to build another it will be the same or wider.
   / Time to build a new shop, need some input. #7
Work out what size you need then double it, my shed at the last place was 6x12x3high, the new place is more than double and 7high and already I am out of space.
Admittedly horses occupy one end.
   / Time to build a new shop, need some input. #8
Both sound great. I think it depends on how you use/need the space. Perimeter walls are great for dedicated work areas, and storage/parts, but if you get large equipment in, then square is great.
Do you need/want floor drains? Separate wash bay? 3 phase power?
Foam insulation sounds good, but sealing the metal is still important rats can and do chew through foam.
If it were me, I would run the water in PEX, so there are no joints under the slab.
All the best,
Peter
   / Time to build a new shop, need some input. #9
The guys on Practical Machinist have been consistently saying that a square shop is the best shape for getting bigger stuff in and out. I think it also tends to be more energy efficient as there is less wall:area ratio. if you don't have big tools that need rigging, then maybe that does not matter as much.
   / Time to build a new shop, need some input. #10
Everyone has focused on the footprint size and footprint shape.
What about height? Can you use your forklift to lift an engine out of your truck (inter') with out running into the roof for example?
What sort of roof are you using? Birds can get in via the ribs on tin roofes. Don't forget the bird blocker that fits the ribs ( forgot the name).
You mentioned a mezzinine floor, is the roof stepped or 1 level?
When my brother laid his concrete floor he laid in pipe for hot water to keep the slab dry, as well as insulation UNDER the slab. This is to stop condensation on the concrete after several hard frosts then a warm spell. He used the diesel ,heater unit out of a dead steam cleaner to heat the slab water pipes. The moderate warmth radiating from the floor also warms the vehicle making it much more pleasant to work on. Underslab insulation on it's own does not stop condensation or a cold floor.
Are you going to harvest the water from your roof? Even if you are on town supply, just using town water for cooking and drinking will make a good sized dent in the water bill.
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
