Timing a MT226D diesel
   / Timing a MT226D diesel #1
reddog848
Canton, Texas
Yanmar FX22D
I posted this on the Mitsubishi board but no help yet.
Can someone tell me how to set the injector timing on a series 2 mitsubishi diesel?:confused: It is a MT 226D tractor and is 35 HP. Under load it will pull down and I can push in the cluth or drop load and it takes a while for rpm to come back up. Also it doesn't rev up as fast a it should. Can I rotate the pump to advance timing or how is it done?:confused2: Thank for helping.
Fred
   / Timing a MT226D diesel #2
red dog if you search for a company in texas called m&d diesel they probably can help you. they have many locations in texas and are based out of houston. it might be that you will have to send or take possibly the injection pump off to be bench tested where all the settings are set to factory specs the injection pump more than likely will be the problem.
mitch becton
   / Timing a MT226D diesel #3
I had an old Iseki tractor with a Mitsubishi engine. On that one, the timing was set with shims inbetween the injector pump and engine block. I'm assuming that your engine is something similar.
2022 Bobcat T66 R - Series Skid Steer (A51573)
2022 Bobcat T66 R...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
