Tips for installing 2 rear remotes on LXX60 HSTC tractors
   / Tips for installing 2 rear remotes on LXX60 HSTC tractors #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
I'm making this post just for anyone else that decides it's time to add a pair or rear remotes to their Grand L Lxx60 HSTC - this information should be universal - and was done on my L4760 HSTC specifically.
First - the 2 wholegoods part numbers you need for the valve control hardware are:
  • L8396 - that's for position 1 valve (so if you are doing only one rear, then you only need this kit and a valve)
  • L8393 - that's for the 2nd position valve, you buy this IN ADDITION to or once you have position 1... they stack on each other)
Second - those wholegood parts are - again - the kits for the mounting of the valve, the connecting rods, handle, quick release... if you are doing this for the first time (like I was) - if you do not ALSO ORDER A VALVE for each kit - you will be sad to learn the day you open the box - there's no valve in there! I don't feel too bad tho - even the parts guy thought they came with the basic valve. So - for each kit you order - you also need to order a valve. You have 2 choices for this tractor:
  • L8308 - this is the basic double acting valve - meaning - you push the lever one way the cylinder will go one direction, at rest the lever will not make the valve do anything and pull it and the cylinder goes the other direction.
  • L8309 - this is a double acting valve with float detent. This means it works mostly like the above valve but if you push the lever all the way forward, just like float on a loader it will pop into a detent and and continue to run fluid until there's enough back pressure to pop out of the detent. Point of something like this - provide continuous flow to something that runs off continuous flow.
Now that you have these 4 parts - you are ready to do the installation.
Perhaps the biggest obstacle to doing this you will hear is that you MUST remove the rear wheel to access a panel in the wheel well to get things connected. If your are flexible - you 100% DO NOT need to remove the rear wheel (which in my case is rim guarded - so at around 800# I wasn't really looking forward to that). You can get everything installed and tightened with the rear wheel on - just make your life easy and DO NOT have a rear implement on the tractor.
There's a couple of youtube videos out there at the time of this post - they do a fair job explaining how things go together - but the biggest challenge here is that the instructions are NOT step by step - they basically give you a part of the kit and some part numbers and tell you to put them together. You spend a LOT of time flipping between the steps they want you to do and the exploded diagram of the entire kit trying to figure out exactly where things go. It's all correct - but not super clear. So just go slowly.
When you are placing the o-rings in the valves and the manifold - use some grease to hold them in there. Doing this will prevent them from popping out at inopportune times.
There's also a few missed things in the diagram as well - so use common sense as you do this. For example there's a big bracket in the kit for the first valve. The instructions show one bolt holding it to the tractor and one bolt attaching the bracket to the manifold for the valves... but - the kit comes with 2 bolts for the attachment to the tractor and there are 2 holes, same for the manifold. Just put all the bolts in all the holes where it makes sense.
For me the biggest win in terms of not needing to take the wheel off was installing the manifold that brings the hydro to the valves - I worked it over and under the 2 hoses I have for the Kubota 3rd function kit from inside the cab under the seat. I did have to loosen on of the 3rd function hoses a little bit to move the hose slightly so things fit. If you don't have a 3rd function, that won't be an issue. If you are ALSO installing a Kubota 3rd function - it's not a bad idea to do this right after to you can move the hose. Once I got that positioned (being sure to no knock out an o-ring) - then I went back around behind the tractor and took the valve bodies with the lever arms that attach directly to them on the long bolts in kit 2 - and attached to the manifold. This was very tight work but very doable.
The hardest part of the entire install is when the connector rods come down from the cab to the lever on top of the valve - you need to insert a very small cotter pin / R-clip in there... you will need nimble fingers and not sausage hands if you leave the wheel on. Just take your time.
Regarding the connector rods that go down from cab to the valves - the instructions tell you to cut through a rubber gasket in specific spots. I found a great way to do that is to tape a razor blade to the end of the rod, align it with the bracket in the cab and then lower it down to the gasket and cut exactly where it should go.
Another tip I can offer is when the time comes to attach the bracket to the back of the tractor that holds the remote connectors. You will be removing 4 small hole covers (fancy grey tape squares) on the inside of the cab. Then you have a plate you need to hold on the inside of the cab that has welded nuts on there and you will then be bolting in from the outside. Sounds like a logistical issue for sure unless you are Mr. Fantastic... or if you have a helper... BUT - to do it solo - just put a piece of tape on the plate and align the holes in the cab... then when you go behind the cab, you can just thread the bolt through. Simple.
Not mentioned in the instructions but the upper bracket you install in the cab that has the actual levers you move - it has this weird bent metal bottom and 2 holes in it... no explanation of why or what for... Look at the wiring harness right there - there are 2 unused push type retainer clips - you plug them into those holes and it ensures the wiring harness will not bind up in the new levers and rods you are installing. Pretty freaking slick.
Overall - this kit is probably "easier" to install than the 3rd function kit - but it's a more complicated installation - if that makes sense. There's just more "stuff" to mess with where as the 3rd function kit is just new hoses and plugging in some wires for the most part. Not having to remove the wheel, however, should make this much more approachable for folks to do on their own.
As for rear cylinders for a top-n-tilt... I'll share the setup and part numbers I used in another post. I saved a LOT of money of the ridiculously over priced Kubota kit and got better "stuff" I think.
   / Tips for installing 2 rear remotes on LXX60 HSTC tractors #2
nice write up. great detail and I love the extra tidbits not included in the instructions. Just one point to correct. The valve with float will not power an attachment continuously it just connects the two work ports and allows a connected cylinder to "float"
so there are kits for the valves and kits for the levers for each valve so two remotes requires 4 kits and 3 remotes would require six kits?
I find it funny that Kubota does not offer a valve kit with normal detent, example to power a wood splitter. I believe the old GL XX40 series had one available. My brother in law has one but it may be a dealer modified valve. His is the factory setup not aftermarket.
i personally would have done three, especially if you are doing top and tilt. If you ever need a remote with the top and tilt hooked up you are back to square one.
thanks for taking the time write it. only thing missing are pics :)
Well - the parts guy was wrong again then... he said that would be the use of the detent... that OR a bungee cord on a regular valve...
And I don't need 3 for sure. Hell - I really only needed 1. And finding the kits during this time of no parts anywhere was hard enough... 3rd was another $800 in unobtanium parts for something that would categorically never get used by me.
And not having to pull the wheel makes it even more worth it ;)
   / Tips for installing 2 rear remotes on LXX60 HSTC tractors #4
re-reading your description of the l8309 valve kit you actually described two different types of valves. the loader type valve would be one with float like the lift function on the loader. push the stick forward past the detent and both work ports are connected allowing the loader to follow the terrain
you also described a valve with pressure release detent most commonly found on log splitters where the valve detents to a work port until the cylinder reaches the end of its travel and the rise in pressure in the circuit takes the lever out of the detent and valve returns to neutral.
I am finding it harder and harder to find someone who actually gives a hoot about the technical details and even some of the more basic details about their jobs. Some people do care but they are getting hard to find. Most just want their pay check and punch out. When 30 minutes on google nets you more knowledge than the salesman, you know you hit the jackpot.
   / Tips for installing 2 rear remotes on LXX60 HSTC tractors #5
I though it sounded like you were adding top and tilt which you need two remotes for.
My valve has a manual detent. it is a little hook bolted onto the plastic fender cover that holds the lever engaged. a little more sophisticated than a bungie cord :).
I can't take credit for it though, the tractor was like that when I purchased it.
2006 Volvo VNL (A51039)
2006 Volvo VNL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
