Chains Tire chains
   / Tire chains #1
repete
Veteran Member
SW Washington
L2550DT IH584-4WD
Anybody know of a good place to get tire chains for a l2550 front and rear?
   / Tire chains #5
Anyone put snowchains on the back wheels of an BX24? When I look it seems very tight on the right side where the fuel-tank sits, please pics if possible, thanks!
   / Tire chains #6
okgarcia,
What kind of chains did you get from White Mountain Chain for your BX24?
I noticed they have very many kinds to choose from.
Thankyou
   / Tire chains #7
HI,
It helps when you fill out your profile,so we know where your from.If it happened to be MAINE,i could make a good reccomendation.
ALAN
   / Tire chains #8
I also ordered mine from tirechains.com, the shipping was a little expensive, but it was still much less expensive than the other quotes I was getting
   / Tire chains #9
The last two tractors had tire chains from tractortirechains.com The dealer said he would take our chains in trade and either modify them or provide new ones for the new tractor. I tried my R4s without chains and it did not work well at all. They are necessary if you want to work in the snow with any efficiency.
Mike
   / Tire chains #10
From my dealer salesguy...about a 3030HSDC (might be relevant)
John, the wheel spacer kit is $297 plus 1 hour install. But note that the spacer kit is not compatible with mid mount mower. That means you will have to jack up and remove spacer kit each year.Then reinstall in fall.
2008 Thomas Freightliner 71 Capacity School Bus #29 (A49339)
2008 Thomas...
TERMS & CONDITIONS (A49251)
TERMS & CONDITIONS...
Midland M86 Pull Type Scraper Series 976 (A49339)
Midland M86 Pull...
3031 (A49339)
3031 (A49339)
New Wolverine Skid Steer 3PT Quick Hitch (A48289)
New Wolverine Skid...
(5) Front Tractor Weights (A46502)
(5) Front Tractor...
