tire size
   / tire size #1
rooftrussman
Northern Virginia
Ford 1210 (1986)
I have a Ford 1210 FWD that has 29x12.00-15 on the rear and calls for 20x8.0-10 but has 20.5x8.0-10 on the front. Will this 1/2" difference make a difference or can the drive train deal with this difference. I wanted to put AG tires on the tractor but calls for 16" wheels on the rear. Not sure I need the AG tires bad enough to buy new wheels unless somebody knows of another way around this. Thanks
   / tire size #2
I'm thinking the size on the front won't matter a whole lot unless you run in 4 wheel drive on hard surfaces a lot. There is some latitude built into the system to allow for faster wear of the front tires -- they start out running quite a bit faster than the rears and can get to where they run at the same speed as they wear down. Check with a dealer -- either tire or tractor -- to be sure.
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2020 KUBOTA RTV...
Kubota BX2230D (A47384)
Kubota BX2230D...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
