Tires for Ford 1900
   / Tires for Ford 1900 #1
paintman161
Rochester, NY
Ford 1900
Looking for less aggressive tires for my ford 1900, which has at tires front and rear on it now. Will be using it mainly in the yard but also in the woods, is there a happy medium tire out there?
Does any one know if 29x12-15 tires would fit mounted on rims already that came off a kubota b7100?
   / Tires for Ford 1900 #3
Would not suggest those from B7100.
An R4 industrial tire on the rear like a 14.9x24 or 16.9x24, R4 on rear would be the tire for the rear, depending on rim size, but front would have to be sized appropriately as the 4wd has to have correct ratio. May be able to find a 16" truck tire to suffice on front.
   / Tires for Ford 1900 #4
Quick question:
I have a 1900 with turf tires on the rear. I want to put AG tires on the rear. Will I have to change the rims in order to accomplish this? (13.6-16 turfs are what I have right now)
   / Tires for Ford 1900 #5
Txford1900,
I have a 1300 that had 13.6-16 turfs on the rear. I recently found a pair of used 12.4-16 ag tires that I changed out with the turfs. The ag tire is about an 1" shorter than the turfs.
   / Tires for Ford 1900 #6
Txford1900,
That's, what I needed to know, thank you ! What's you end up having to pay for the used AG tires?
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2018 RoGator 1100C (A53472)
2018 RoGator 1100C...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
