Tires Tires leaking
   / Tires leaking #1
stump54
Bladen County North Carolina
MF-2607H, MF-1540, MF-GC1710, Ferguson TO20
The other day I noticed water on the barn floor around my tractor (MF1540). Looking closer I noticed both rear tires where wet, on both sides of the tires, around the bead. It looks to be a one time leak, as the floor is now dry. Could this have been caused by our drastic temp changes here in NC lately? Should I be taking it to the shop?
Thanks,
Gary
   / Tires leaking #2
Gary, If it has been cold there for a while and your tires are filled and now its unseasonably warm ,yep they are probably sweating, just like a cold glass on a warm day... good ole condensation
Mark
   / Tires leaking #3
I agree, definitely sweating from the rims because of the warmer humidity and cooler rims....
   / Tires leaking #5
Hey Gary,
I noticed the same thing today on my John Deere--sweating tires. I live in the southern Piedmont of NC, and today was much warmer than the last several days.
I was wondering, have any of you had actual leakage from around the bottom of the rim? I did, a very small amount, and it concerned me. I added some air to each rear tire, but there still seems to be a tiny wet spot at the bottom of the rim. Haven't noticed until very recently. Both rears are loaded with water/antifreeze mix. Is this normal for this time of year?
Thanks,
Matthew
P.S. Nice looking Massey, Gary!
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2008 FORD F-750(INOPERABLE) (A50854)
2008 FORD...
HEAVYEQUIPMENT ROLLS OF CONDUIT (A50854)
HEAVYEQUIPMENT...
