Even though you tractor is 4wd it isnt really 4wd
Here you go.. this old 1937 video explains how a differential works better than anything I have ever seen. Keep in mind you have 2 differentials a rear and a front. but If you can follow this you will understand. The first 2 minutes seem worthless, but there is a purpose stay with it.
Auto Mechanics: Differential: "Around the Corner" 1937 General Motors 9min - YouTube
James K0UA
Curious why you would say that? Then what would you call it?
James that is a good video, thanks for posting.
It is 4WD as long as the resistive/tractive forces are equal on a per axle basis. In other words, as long as the front tires have have the same load on them they will both turn. Same for the rear's. But if they are unequal on a per axle basis then it is possible to only turn one wheel/tire and the other to be stopped. I have seen many times when only 1 tire per axle is spinning, and many times when all 4 are spinning. If you use your rear differential lock you can guarantee 3 tires spinning .
James K0UA
