Tires $$$$
   / Tires $$$$ #1
rvaitor
Platinum Member
Nashville, TN / Hickory, NC
Kioti DK55C
I did a search for tires and didn't find a discussion on the cost of tires and also if you can convert to R4s from R1s or the other way around.
Here are the tire sizes on the tractor I am looking at.
12.5/80x18 / 19.5Lx24 industrial
11.2x24 / 16.9x28 Ag
I'm thinking those are different size rims, but maybe I don't know how to read sizes??
Also, what are folks paying to replace tires?
Thanks,
   / Tires $$$$ #2
My b7800 came with R4's. I bought a set of R1's,I had to buy rims also. They are a narrower taller tire. As far as the cost from the dealer ( hope your sitting down.) $1100.00
   / Tires $$$$
Well,
That was what I was thinking - rims and tires? What do tires alone usually run - installed?
Thanks again.
   / Tires $$$$ #4
And on a 4x4 tractor remember that front and rear tire diameters need to be matched to a ratio. You can't just put bigger tires out back if you want to use 4x4.
2008 Toyota Camry LE Sedan (A44572)
2008 Toyota Camry...
C20 Roll Up Door (A47484)
C20 Roll Up Door...
FSQ SAF 544 Pillar Block Bearing ( 3) (A47484)
FSQ SAF 544 Pillar...
Toyota 42-6FG25 5,000 lbs Warehouse Forklift with 3-Stage Mast & Side Shifter (A46877)
Toyota 42-6FG25...
2025 Wolverine GB-11-72W Grapple Bucket Attachment (A47484)
2025 Wolverine...
2014 Ford F-350 Omaha Service Truck (A44571)
2014 Ford F-350...
