TL2100 info for owners
   / TL2100 info for owners #1
corelokt308win
What follows is a list of info in regards to the Tl2100F I own, I hope it may of help to others, esp. the glow plug info as it includes part numbers.
TL2100F INFO
Engine model# located behind fuel filter, starts with a "3" ie. number of cylinders.
Filters:
Oil: Napa 1348 (B159 Baldwin) if 3/4 -16 threads
Napa 1344 (WIX 51344) if 20mm threads
Fuel: Napa 3262
Air: Napa 6326
Car Quest 88326
Hydraulic: Cleanable element
Fluids:
Motor oil: Rotella (Summer)
5w30 (Winter)
Hydraulics: Standard Hydraulic Oil
Power Steering: Hydraulic type 55 oil, or Automotive Power Steering Fluid.
(Located under battery, has a drain plug and a filter screen)
Front Axle: 80w90
(Fill until covers axle shaft as seen through fill hole).
(Drain by removing the wheels and removing drain plugs).
Grease Fittings: Standard Wheel Bearing Grease
Glow Plugs: Iseki part # 618241000810
Isuzu part # 9-82511978-0
NGK part# Y104 / stock# 6425
   / TL2100 info for owners #2
I see some people saying these should take 80-90 weight in the front axle but my manual says universal tractor hydraulic transmission. The TL 2101 FD I just bought with less than 250 hours on it definitely had tractor hydraulic transmission fluid in it not gear oil.
   / TL2100 info for owners #3
I bought a Iseki TL 2101F, it had 80w or 90 W in the transmission/ hydraulics, it was milky when I bought it and on days below 39 degrees it would squeel an chatter the hydraulic lines am filter, I washed the filter element, put in 80w90 gear oil an still have same sound on low temperature days,it's causing bubbles in fluid cavitation is occurring.what type of fluid should I change too? these tractors weren't ment to be ran in the winter but I need to use it in the winter.there rice field tractors in water mud when they were sold in 1980 thru 1985 before tl2101 became tx220 I think. on another thought could I thin the 80w90 out with sae30 or Utf?
   / TL2100 info for owners #4
Hi
I have just bought a "new" TL2100 and It came without manual. I have just found similar ones of TE3210 and TU 1900, but they are not exactly the same as TL2100
Anyone knows how to get the manual?
Best regards.
2013 KENWORTH W900 TRI AXLE (A47001)
2013 KENWORTH W900...
2001 HORSE CREEK MANUFACTURING LINE HEATER (A47001)
2001 HORSE CREEK...
County Line Spreader (A47809)
County Line...
2012 SHOPMADE FLARE STACK GOOSENECK TRAILER (A47001)
2012 SHOPMADE...
2008 HOLDEN INDUSTRIES, INC 100 ANTENNA TRAILER (A47001)
2008 HOLDEN...
Whiteman 48in Concrete Power Trowel (A45336)
Whiteman 48in...
