TN 65 Hydraulic Quick Couplers are leaking
   / TN 65 Hydraulic Quick Couplers are leaking #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
When I first bought the tractor back in 2000 one of the QC's developed a leak and my local dealer replaced it under warranty. Well I can't complain as they lasted for over 10 years but right now I have 2 leaking for sure and I think a third is leaking as well (hard to tell with how their stacked on each other). So I am curious if there are a simple rebuild kit for these or if its better to replace them. If I replace them I would like to either stay the same or upgrade to a higher quality QC. I use them a lot so I want something that will hold up and work like it is suppose to without any problems. So for you guys who know more then I do what would you suggest? Rebuild (if possible), replace with the same part or upgrade to a better QC?
   / TN 65 Hydraulic Quick Couplers are leaking #3
Does it leak when in use, or when disconnected? If it leaks when in use wouldn't it be the o-ring in the QD (available at TSC and other places)?
Aaron Z
   / TN 65 Hydraulic Quick Couplers are leaking #4
I went through the same issues on mine. I have an S model, which means the higher grade coupler. At the time I had a leaker, I paid ~75-80 for it. The next one is not the 'one hand coupling model', but a regular ISO unit (you have to push the collar back to allow connect/disconnect). It was only ~$27. I have replaced one or two more.
I found a bunch of corrosion behind the floating chamber of the push/pull/auto model.
Mine is just the standard TN65 but has the one handed connections as well.
As for if it leaks when in use or not well I don't know, I have had something plugged into all 6 of these couplers for the last couple months. I will try to clean them up and take a better look at everything.
   / TN 65 Hydraulic Quick Couplers are leaking #6
Robert, I checked the parts list at messicks.com and they have the following seal kit listed. It's probably an o-ring and teflon backup ring for the female QD.
Part Description SEAL KIT
Messick Notes
Part Number 1534623C1
Stock Status 2 In Stock
Price $4.52
Messick Notes
Price $4.52
Thanks, i had looked on there and it appeared they pushed for replacing the qd instead of repairing. I'm going to see what the loose one I have laying around looks like and if its easy to repair or not.
   / TN 65 Hydraulic Quick Couplers are leaking #8
I think you'll find that you can easily pick the old seals out using a small jeweler's screwdriver. Changing them on my QDs is a snap.
   / TN 65 Hydraulic Quick Couplers are leaking #9
I know this is an old thread, but I have a TN75A and wondering how to release the quick connect coupler. I don't see a external collar on the female part of the connection - only a spring-loaded cover/cap. Thanks,
   / TN 65 Hydraulic Quick Couplers are leaking #10
You might have pressure built upside, in which case you need to relive some pressure. Can you take a picture? I have never seen a coupler without at least a release pull back collar.
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
Adams Conveyor (A51039)
Adams Conveyor...
19010 (A48082)
19010 (A48082)
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
