Buying Advice TN owners - advice on options
   / TN owners - advice on options #1
Trail_Time
PA & VA
New Holland TN70, TC45D and 1320. Kubota M4900, JD 997
OK, I am going to order a new TN this week. This question is for TN owners... I need your input as to any options you have or like that I may need and are not listed below:
TN70A
4WD
16X16 power shuttle trans
16.9 gpm Hyd pump
16.9x28 R1 rears with fluid
12.4x20 fronts
2 rear remotes
32LA QA loader with mid mount valves
Grill guard
thanks
   / TN owners - advice on options #2
I'd also opt for the supersteer option, and I'd personally go for R4 tires. The cab is nice, too. Then, of course you'll need a box blade and backhoe...
   / TN owners - advice on options #3
The R-4's are nice if all you do is loader work on hard ground. Get into some slop and they are useless.
The only thing that comes to mind is that you might want a block heater and a canopy.
   / TN owners - advice on options #4
Good selection. I think I purchased the larger tire option - and they are radial, which I like (vs the bias ply). I did have them filled as well. Also, the block heater is a worthwhile investment in cold areas.
I like having the quick attach bucket...and I belive I have the 32LC Loader, which is working well.
Good luck.
   / TN owners - advice on options #5
Good choices...nearly the same as my TN65. I have the 32 LA loader which used the two remotes in the back. I had to have a 3rd remote so I could use my haybine, round-baler, disk, etc.
R-1's are certainly better than the R-4's if you're doing farming and such. 4WD is a must, especially if you're on a hill or doing plowing.
Good luck.
   / TN owners - advice on options #6
You may also want to upgrade your fixed link ends to the flexible link ends on your 3PH, and like someone else said a canopy -
I just installed the steel FOPS canopy on my TN75, due to work in the woods. Hopefully I will never get to test it. It was not cheap either -
You may also want to negotiate before purchase: your first service, delivery charges, and any pick up/delivery charges you may incur if you need warranty work. /forums/images/graemlins/cool.gif
And don't forget the free hats!
Hopefully your wait will be short /forums/images/graemlins/smile.gif
thanks for all the tips. Ordered yesterday.
Thanks Bryan Messick and Neil @ Messick's Equipment for the good deal!
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2017 Ford Escape SUV (A48082)
2017 Ford Escape...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2022 Argo Xplorer XRT 570 LE 4x4 ATV (A48082)
2022 Argo Xplorer...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
