TN-SS TRANS PRESSURE SWITCH HELP
   / TN-SS TRANS PRESSURE SWITCH HELP #1
DASDAVID
PALM CITY FLORIDA
TN55
Hi folks, David from Florida.
I currently have a TN-55 with several headaches. Some I am solving some not. Today my issue is the trans pressure switch I bought one and can't seem to find it on the tractor.
On the left side I have found what I thought was it (disconnected and looks like it has been for a while, you can see it through the e-brake slot other than that I see no switch that looks like mine.
Any suggestions would be great
   / TN-SS TRANS PRESSURE SWITCH HELP #2
You will have to look on the parts diagram. NH.com or something like that. It may not be listed in the obvious chapter. Shouldn't be too bad to find. Good luck!
Oh -- you can search for all the other variants of that tractor here and see if someone else has covered that. Probably in a similar location for most of them.
for anyone else needing the information the switch is located above the fuel tank after removing the left rear tire. It is the larger switch located just above a smaller one
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
International 133 6 Row Cultivator (A50514)
International 133...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
Bus (A50323)
Bus (A50323)
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
