TN75DA CODE 77
   / TN75DA CODE 77 #1
Ironhorse0484
Code: 77 Internal ECM supply voltage (8V) is too high.
Condition: ECM detects that the voltage at ECM connector 2, pin35 is above 8 volts.
Code causes: Faulty ECM. ECM connector 2, pin 35 is/was shorted by an external 12 volt source. Internal circuit short to 12 volts.
NOTE: Connector 2, pin 35 is not used externally as an actual output. There is no wire coming in/out of pin 35. I checked the voltage on the pin. It is at 7.96 volts.
Effects: Transmission is critically disabled. Will not move.
Has anyone seen this problem/code before? Is the controller the only problem or did something else cause the failure? If I install a new controller will the same problem occur and burn up a new controller? Im leaning towards controller because of the code. Other component failures SHOULD throw another code. Any help would be great. Thanks alot.
   / TN75DA CODE 77 #3
Sounds like you will need to contact the nearest dealer service department. It actually sounds like a faulty contact.
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
HLA SE50AO600G LOT IDENTIFIER 31 (A53084)
HLA SE50AO600G LOT...
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
MANTIS 155B LOT IDENTIFIER 248 (A53084)
MANTIS 155B LOT...
