TN75DA CODE 77
   / TN75DA CODE 77 #1
Ironhorse0484
Code: 77 Internal ECM supply voltage (8V) is too high.
Condition: ECM detects that the voltage at ECM connector 2, pin35 is above 8 volts.
Code causes: Faulty ECM. ECM connector 2, pin 35 is/was shorted by an external 12 volt source. Internal circuit short to 12 volts.
NOTE: Connector 2, pin 35 is not used externally as an actual output. There is no wire coming in/out of pin 35. I checked the voltage on the pin. It is at 7.96 volts.
Effects: Transmission is critically disabled. Will not move.
Has anyone seen this problem/code before? Is the controller the only problem or did something else cause the failure? If I install a new controller will the same problem occur and burn up a new controller? Im leaning towards controller because of the code. Other component failures SHOULD throw another code. Any help would be great. Thanks alot.
   / TN75DA CODE 77 #2
There is only one cause for code 77; a faulty ECM. I've changed several ECM's and NEVER had a repeat failure.
   / TN75DA CODE 77
Thanks for the help. I was sure that was it, but another opinion always help.
Sorry on the double post. Just signed up, first time posting, things go that way sometimes.
2018 HINO 268  NON CDL 26FT BOX TRUCK (A53426)
2018 HINO 268 NON...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
CAT 257D (A50123)
CAT 257D (A50123)
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
