TN75s errore cod 13
   / TN75s errore cod 13 #1
Liga
San Martino in Rio
New Holland
Hi, i have error code 13 on my new holland tn75s. What is it?
   / TN75s errore cod 13 #2
There are 2 error code 13's. One is the 4wd engagement circuit.....it says 4wd is permanently engaged....causes 1. short circuit to ground 2. Solenoid terminals disconnected 3. naked wire. The other is "Hi-Lo P. buttons"....activated when they are pressed simultaneously....causes 1. both pressed simultaneously 2. Lo-P button pressed and high locked 3. Hi-P button pressed and Lo locked....This is a problem with the power shuttle. What year is your tn75s? Mine is an '02 and the manual I have is for 98 to 03 models. I hope this helps. Let us know. I bought the manuals after I had error code 33 for a couple of years....dealership no help. Turned out to be a faulty tilt sensor which was easily identified using the manual.
Ok, thank you. I have a problem with 4wd. I have to check all cable and terminal.
My tn is '99
   / TN75s errore cod 13 #4
You are welcome. Let us know what you find!
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
2015 DODGE RAM...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
